1756-Eweb Error 16#0204
Bolatov
Jun 2010
Mty
87
Hello Guys
Im using the 1756-EWEB card to gather information from tight tools. It has 6 sockets.
All mornings when I monitor the program performance I see the I/O Not Responding in the RSLogix and I see that the 1756-EWEB is faulted with the error 16#0204 Connection Request Error: Connection request timed out; some sockets are working, some are not.
The solution I have found so far is to reset the module, and after that it works fine all the shift.
But I have to do this all mornings...
I talked with Tech Connect but they really cant tell me what is going on...
Any of you have experienced something similar with eweb?
You describe "I/O Not Responding" errors... Do you have any devices with I/O connections through the EWEb ?
The EWEB should not support cyclic IO connections at all.
0x204 is the ordinary timeout code.
I have an Ethernet cable from the Eweb to a hirchmann switch, from this switch it goes to The 6 Torq Tools from which im receiving the information.
When I see the failure some of the sockets are working and some are not, however they are not always repeting, I mean some days some fail and other days the others fail
But the strange thing is why the module it self faults
Why I cant reestablish all the sockets connections until I restart the module
Am I doing something wrong when starting communication? overflowing the eweb or something like that?
Thanks for the screenshot !
I can't begin to diagnose this one. You really need to take the issue directed to RA Technical Support.
Extended Error Code : 16#0000_0204 "Error Processing connection related service" After Deletesocket or DeleteAllSocket, this error always...
2,456
Does anyone have downloads of the TN 42799 and TN 49389 technotes? They are no longer available on Tech Connect.
1,636
I have updated the firmware of the EWEB module first to 5.001 then to 4.016. I have updated the firmware of the 1756-L73 to v28. The device is...
1,520
Hello, There used to be a toolkit available through Allen-Bradley for the 1756 EWEB card to assist the development of webpages. Allen-Bradley...
1,515
hi, i follow the manual to setup server and client for 1756-eweb card but i have some question, is there anyone who have program for both server...
1,081
