1756-IA 16/A
1756-IA16 is a 120V AC input module. Consult the module specifications if you need to find a suitable module.
The /A is a shorthand indicating that it is series A, ie the first version. If Rockwell were to release a version with different hardware (for example due to component obsolescence) the new version would be series B, then C for a change after that &c.
Thanks for your response plvlce, and sorry for the typo, I meant 1756-IB16 instead of the AC input card I wrote yesterday. With the version question out of the way:
For the DC input card 1756-IB16, could I use it with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one?
See page 41 of the manual linked to in post #2, it will give you the voltage values that it will switch at.
If you want to make sure that it will switch with TTL inputs you will need a 1756-IG16, but they are low = true and high = false.
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
77
376
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
150
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
98
please using the usb can i assign any ip address that i want ?
153
