1756-L61 WallClock time incorrect
dlsutherland
Oct 2009
MO
I have, on few occasions, had to correct the time in the CPU. Our power here will go out from time to time so the first thing I did was check the battery. The battery is good so any ideas or similar experiences as to why the cpu would not keep the correct time.
From the Rockwell Knowledgebase: Time of Day Clock Accuracy - Maximum variation at 20 degrees C is 3 min. 4 sec. per month. The other thing to consider is the setting for Daylight Saving Time.
I utilize a clock sync bit between a master controller and all the remote nodes. Currently I have 45 PLC's of various vintages. Of course, this was all put in place prior to the clock sync tool.
Hi All, I'm trying to upgrade from 1756-L61 to 1756-L71 but I keep getting an error 25299-0. Is there anything that need to be complete to be...
1,857
Hi; I am experiencing a problem with AB 1756-L61 controller that it doesn't retain the program while battery is connected. I have found that...
2,794
hello i had a 1756-l61 with firmware ver 13.24. a solid red made the processor not functioning. i ordered a processor that came with firmware ver...
3,852
Hi, we are using 1756-L61 PLC redundant system in one location . due to some minor faults , we upgrade the firmware from 19.52 to 20.58. after...
1,346
1) I am currently trying to integrate a Prosoft MVI56E-MCM Module into a 1756-L61 CONTROLLOGIX5561 that is a redundant system (CPU is redundant...
3,454
