1756 net eni to serial on a pl5
Kenneth_Horn
May 2012
Albany, Oregon
Can I hook an Allen Bradley 1756-net-eni device to a 25 pin serial on an Allen Bradley PLC5 processor. Putting in an ethernet card at this time is not an option in the rack. What would be my mini pinout wiring to the serial 25 pin on the plc 5 for ethernet connection to my office desktop? thanks
Hi
I have seen this on a plc I work on so yes it can be done
But sorry I don't have the pin out. I am on that site next Monday
If you don't have it by then I could bell it out and get it for you.
Donnchadh
Yes, it will work.
You must switch the PLC-5 serial port to CRC error checking; the default is BCC and the Net-ENI uses CRC only. Set the serial port baud rate to the highest available; usually 19200.
The best cable is just a 1761-CBL-PM02 (the ordinary MicroLogix cable) with a generic 25/9 pin adapter.
First of all, I'm a second year college co-op student, so forgive me for being so fresh. I have my PLC writing messages to the proper nodes of...
1,340
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
199
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
870
Hi Guys. I am trying to get access to an older chassis to see a 1756-55 processor, the chassis has the older 1756-ENET card, Linx cannot see it...
624
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
628
