1756-OB32 Power Monitoring
iahiii_2005
Jun 2008
Oslo
How i program so that i can monitor if 1756-ob32 is functioning in other words still working,in conjunction with monitoring with an input module.I will be using a switching mode power supply for the rack.
Are you asking will a 1756-ob32 (and uhh what is that?) operate when supplied by a switching power supply?
What is it normally powered with - uhhh what does manual say?
Dan Bentler
Outputs do not come on when energized in plc program. Card has 24 v to it and a common wire
195
Hi folks, I was called to a job where a "new system" (panel was built in 2022) was having unexpected problems. It is a ControlLogix 1756-L71 with...
1,042
Hi all, IÂ’m having issue on 1756-OB32 where one of the channel (CH14) keep on has 24vdc, causing my solenoid keep on energising without command...
1,765
Hello colleagues. Need your help. How to get channel data from 1756-OB32 without adding to IO configuration? How to use the CIP Generic...
835
Hello Group Hope everyone is well I've used the 1756-OB32 in the past, but now need to use the 1756-OB8 due to space limitations. I've reviewed...
1,924
