1761-cbl to 25 pin
nate8108
Aug 2005
chatham on
Hey everyone,
I am trying to comunicate between a printer and plc..
I know the logic is right because it is running in a plant right now. What I can't figure out is the pin out between the 1761-cbl and 25 pin conector... what I did was sacrafised a 1761-cbl and cut the 9 pin serial side off and want to sodder a 25 pin connector to the end so it can connect to the printer cable. the pin of the the 1761-cbl is as follows . ...............................................................- 2........................1-24v my prntr cbl pin out is 1-F. GND
.........................2-GND.........................2-TXD
.........................3-RTS ........................3-RXD
.........................4-RXD ........................5-CTS
.........................5-DCD ........................7-S. GND
.........................6-CTS ........................6-DSR
.........................7-TXD ........................20-DTR
.........................8-GND
Now the pin out for the printer sais that 6 and 20 on the printer cable are connected. If any body has any help on what the pin out should be could you please give me a hand Thanks
I ordered purchased a 1761-cbl-pmo2 from ebay, only to find the 8 pin mini din connector cut off and missing. Does anyone know where I could...
4,776
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,073
Is there a cable that I can buy that is the equivalent of the 1761-CBL-PM02 plus a null modem and gender changer? I have some new radio modems...
17
5,983
So, I need a RS485 Modbus slave to do some testing. Well, since I don't have any RS485 Modbus Slave sitting around but does have a Micrologix...
3,268
Good day, I have a little problem with connected a PLC micro 850 Allen Bradley with a HMI C200. Already connected PLC with ethernet cable in my...
1,414
