1761-NET-AIC Question
mikeyboy
Mar 2008
PORTLAND
Hello I am new to the industrial networking idea. We currently have about 8 Micrologix 1200's and 1 SLC 5/03 that need networked to gether to feed into a new Red Lion G3 touchscreen that will be used as a monitoring station. Currently the PLC's do not have 1761-NET-AIC as optical isolators. If I network these together using DH-485 do I need to add the NET-AIC modules or will it still work without them?
You need to use the AICs.
Serial ports on MX1200 are RS-232, you need to convert them to RS-485 with protocol DH-485.
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Complement of information
Fuzzy logic is right....
Comm port on a Micrologix 1200 is RS-232.
DH-485, is a variation of RS-485 (proprietary to A-B). the signal level are not the same, therefore you need to convert the RS-232 to DH-485.
on the NET-AIC, the DIN connector and the DB-9 are the RS-232 side, while the Phoenix-6 is DH-485
For you SLC, you will need to use a 1747-AIC, to isolate it and to provide the appropriate mean of connection.
you maximum cable length will be 4000 ft
hope that help !
Jasmin
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,797
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,954
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,071
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,793
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,009
