1761-net-aic
ahortor
Jun 2006
Michigan
I have a 1764-micrologix 1500 LRP series C, processor. On the channel 1 which is on the side I have a scanner connected. The panelview I have is a PV300 with DH485 protocol(2711-K3A2 PV300 Key, FRN 4.10-4.xx).
My question is, do you use the 1761-CBL-AS03 cable to connect to the AIC+, and if yes then how do you communicate with everything once channel 0 of the processor has been changed to DH485.
Or is there an easier way.
You are on the right track. The 1761-CBL-AS03 cable connects the Net-AIC's DH485 trunk connector to the PV300, and you connect the MicroLogix and your programming PC via the two RS-232 ports.
If this is an OEM sort of application, get cables that will power the Net-AIC from the MicroLogix by using a 1761-CBL-AM00 cable (round-to-round), then use a 1747-CP3 to connect your PC to the 1761-Net-AIC. If you're looking to simplify your cable assortment you can use two ordinary 1761-CBL-PM02 cables, which most people use to download programs to MicroLogix controllers.
The configuration you describe is just like the "3-node network" shown on page 24 of the new edition of the 1761-NET-AIC User Manual.
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,797
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,954
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,071
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,793
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,009
