I need some help assigning an IP address to a 1761-NET-ENI.
We received the ENI with an IP address of 200.200.200.1 per their documentation.
I plugged my PC into the ENI(via crossover cable) and ran BootP. BootP never detected the device. I attempted to add New and entered the Ethernet address along with the IP and subnet. When I selected the added item the "Enable BootP" & "Force IP Renew" buttons remained grayed out.
I downloaded the ENI Configuration Utility (Series B) and connected my PC to the ENI via 1761-CBL-PM02 cable. It would attempt to communicate but kept popping up the same error message ("Check Cable or Port Settings"). Under "Utility Setup" Tab I selected COM3 and 9600. Under "ENI IP ADDR" Tab I selected Baud Rate = Auto.
I'm typing these message from Home so some of the descriptions/info may be a little vague.
Does anyone have any info that might help me?
Thanks!
Thanks!
