1769-IF16C Compactlogix current analog input module
Hani ahmed
Jul 2009
cairo
17
After reading the 1769-IF16C compact Logix analog input current module field wiring connection we noticed that it be used only with 2 wires and 3 wires current transmitters.​
Could any one please advise us how we can connect 4 wires current transmitter to this module.​
Signal conditioning can include amplification, filtering, converting, range matching, isolation and any other processes required to make sensor output suitable for processing after conditioning not converting wiring for incoming signal from field transducer from 2 wires to 4 wire
the picture is the our module filed wiring where the transmitters are 2 and 3 wires only and uses com point for all -IN transmitters and each signal connected to +IN.
so if we need to connect 4 wire Transmitter can we connect our signal to +IN and -IN connected to com point with the others of 2 and 3 wires transmitters?
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
137
Hello, I was wondering if anyone has any leads on a 1769-IF16C Digital Input card? I need one for testing systems, doesn't need to be BNIB, just...
1,718
Can I use 4-wire with the 1769-IF16C? The 1769-IF8 has a COM for each input and the IF16C only has 2 Com.
1,075
I got 14 Yokogawa Admag AXF Flowmeter going to this card on a Micrologix 1500. Just realize that a 4 wire instrument will not work with the card...
1,781
Hey Guys, I have a few questions regarding a 16 channel analog input card for compact logix. 1769-IF16C. In the Module-Defined tags that get...
2,168
