1769 IF4xOF2 question
dougpdf
Feb 2014
kentucky
48
This is my first time using a 1500.
Now that it's installed I see that the minimum change (input) is 128 bits. I suppose this is what's meant by "low resolution"? I remember buying this (forever ago) as I use the output to power my linear pots in lieu of a 10VDC supply. Seemed like a good plan at the time.
Anyhow, this equates to .005" in my application. Not very good. It's determining positions of a hydraulic cylinder on my injection press.
With this in mind, how much better would the IF4 module be?
I'd like to get more accuracy
Showing my ignorance here...
Thank you!
Thanks Mickey
I've been searching to figure out where this is located...
Does a similar sheet exist for the If4xOf2 for me to compare?
I have a spare input on my IT-6 module. Would it be better?
One decent input would work for me.
Thanks a bunch !
Thanks a bunch !
See picture...
A 1769-IT6 is a thermocouple/mv module greatest mv range is 0-100mv.
Updated picture for IT6 module...
I have Studio 5000 v30 and trying to set up an analog input. I noticed through another thread there are extra steps. I looked up the manual and I...
529
I am getting max counts on my analog input 32640 on a temperatur transmitter. I have a compactlogix L24ER and I added a 1769-IF4XOF2 in slot 2...
37
3,127
Hi all wiring in the above card and the PDF from AB is fairly vague in showing how to wire in a current output. I am connecting a sampson valve...
2,584
If you notice on the bottom right it looks like two little clips coming off the module. A third clip should be just to the right of the two you...
1,547
Hello Everyone, I'm terrible when it comes to communication and its protocols. Keyence has provided me with the BT-A700 Wireless Scanner which is...
51
