1769-IF8 Analog Input Card with Micrologix 1500
Elcan
Apr 2008
NC
935
Hi all,
I have a 1769-IF8 Analog Input Card in a Micrologix 1500 system.
The card does not read any inputs. I already checked the wiring and it seems to be OK.
Any ideas?
Thank you in advance!
Hi all,
Any ideas?
You have to configure the card prior to getting any readings.
Thank you for your responses!
I think that the card configuration is correct, but I'm posting one of the tabs of the configuration window.
Can a analog card properties settings such as RTS and filter frequency can be changed with CPU in run mode without causing errors or issues...
1,899
Good Morning , I have a 1769-IF8 analog ( 4-20 ) input card. Using a calibrator, but the 4-20 signal is jumping around . It is not too...
2,771
Hi everyone, I am doing an automation project and i am using a signal conditioner to supply an analog input card with 4-20mA. I have setup a SCL...
2,496
I know this has been covered before, but I can't get this scaling to work in Logix Designer/CompactLogix 1769-L33ER project. I tried to: -...
3,619
Could someone tell me which of the available tags in a 1769-IF8 analog module is typically used for the output of an SCP instruction. I am...
66
11,972
