1769-L16 Fault Mode
JeffKiper
Jun 2006
Indiana
2,465
I'm looking into the fault codes of a 1769-L16 the tag is Local:1:C.FaultMode. I know its simple and Im just overlooking the simple answer in the manual. I've looked at multiple manuals and can't find what the values mean. Can you point me in the direction?
Local:1:C.FaultMode
I don't know the answer off the top of my head but I'm interested in it since POINT I/O is a favorite of mine, and the embedded I/O points in a 1769-L1x controller are basically POINT modules.
The tag is displayed in Binary mode in the tag browser: 2#0000_0000_0000_0000
It's a Configuration tag, so it's part of the data that's sent to the I/O at startup, rather than a diagnostic value.
After fiddling with the Fault/Program Action tab for the embedded Outputs, I concluded that each bit in the C.Fault Mode tag is set =1 for "hold last state" and =0 for "go to value designated in C.FaultValue".
Ken as usual you make it seem easy. This whole time I looking at then config when I shouldnhave been looking at the I.Fault
Im building a few faceplates for the PV 5000 screens. Looking at the status of the controller.
Dear all, First post on the forum. my supervisor and I have a 1769-L16-B1BB acting up in the field. We decided to program and send an identical...
2,503
Hi All, Got a project which has specifically called for a L16 compact logix, to control 11 motors, all using the E300 module. All was well and...
22
7,309
Help. Perhaps you can help. I am trying to connect to a 1769-L16 with a USB cable. I’m not having any luck. New program, new controller. After...
2,318
I am using RSLgix 20.0 and RSLinx 2.59 When i try to connect to L16 controller i get the error "Attribute value not settable". In offline mode the...
1,412
We had a Processor Failure yesterday. Opened a new in the box Processor, and could not get BootP to work with it. After a few hours of trying...
214
