1770-KDF Adapter Question....
JoseM
Jul 2011
Texas
381
Got a question on DeviceNet. I have a few 1747-SDN scanners Rev. B with firmware 4.15 that I will like to update them to firmware 6.02.
I was looking around the maintenance office of this company where I recently started working and they have the 1770-KFD DeviceNet adapter.
Can anyone help me learn how to use it? If I have a "Passthrough" driver already configured, do I need to delete it before I can configure the driver for the 1770-KFD?
Do I connect directly to the scanner and update using the "Control Flash" tool given to me by Rockwell Software?
I notice that on one of the control panels at our plant looks like it has more than one 1747-SDN scanner, I need to upgrade everyone of them, correct?
Do I need to disconnect the DeviceNet cable from the 1747-SDN and connect the 1770-KFD directly to it so I can flash it?
Because I don't see where I can tap in on the current DeviceNet network with the adapter in order to talk to all the devices..
You will need a piece of DeviceNet cable "pigtail"ed from the scanner's DeviceNet connector to the 1770-KFD network port connector.
I am replacing an AB SLC 5/04 with a 5/05. The existing connection from the 5/04 connected to the KF2 via DH+ to talk serially via DF1 protocol...
1,876
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,552
I am new to plc and DeviceNet.In the 1749 devicenet scanner module datasheet, I read that I need a 1744 KFD to connect the DeviceNet scanner with...
1,001
Anyone have an idea what "ROM Segment Fault" means when booting up an old 1770-TA Programming terminal? The manual gives not reference as to what...
1,311
I have an SLC 05/04 that I am trying to connect to. The RS232 port is connected to a screen and the PLC is on the DH+ network. The system has a...
1,864
