1770-KF2 not visible on DH+ Network
odonnea2
Oct 2006
Dublin
17
I have a 1770-KF2 module daisy-chained to an SLC 5/04 PLC (Node 1) and two PanelView HMIs (Node 3 & 4).
However the KF2 module (Node 2) is not visible on the network using RL Linx or RS Logix. The relevant switch settings on the KF2 module are configured for DH+ as follows:
SW2/SW3/SW4: set for Node 2
SW5: set for 57600
SW7: Set for DH+
The KF2 module is linked into the DH+ network at the PLC.
The DH+ cable has been tested and is good, power is on to the KF2 module and all connections are secure.
Is there anything I am missing?
My next step will be to try and replace the KF2 module.
Can anybody suggest another alternative.
As it turned out the 15 pin connection set up was incorrect.
DH+ cable had been connected to pins 9, 10 & 11, instead of 6, 7 & 8.
When changed to the correct pins, the KF2 was visible.
I am replacing an AB SLC 5/04 with a 5/05. The existing connection from the 5/04 connected to the KF2 via DH+ to talk serially via DF1 protocol...
1,869
I have an SLC 05/04 that I am trying to connect to. The RS232 port is connected to a screen and the PLC is on the DH+ network. The system has a...
1,850
hello I have the old 6200 software still on a computer with dos 6.22 we keep this around for the older guys. It uses the 1770-kf2 data hwy...
6,610
Hi guys, I was requested to upload any relevant mapping files inside this 1770-KF2, as well as extracting any possible information from this...
1,968
We have a DH+ network with PLC-3 and PLC-5 processors on it. Communications to the network is via a 1770-KF2 module. We want to replace the PLC-3...
2,900
