1794-ID2 Encoder Module with Push-Pull Encoder
Feb 2012
UK
57
Hi Everyone,
I need help with setting up 1794-ID2 Card with push-pull type encoder with A+ (Up counting) and B+ (Down Counting).
The 1794-ID2 is connected to Controllogix PLC Via Flexbox over Ethernet. I could see the Module in PLC config and with added Add-on profile, I could access all the module defined tags.
The Way I set up the card is as follows:
1. Set the module to count up on Positive signal on Input A & count down on Positive signal on Input B by setting Tags Output.Ch0ModeSelect2 =1, Output.Ch0ModeSelect1 =0 & Output.Ch0ModeSelect0 =0
2. Not using Gate function, set the tags Output.Ch0GateControl9 = 0 & Output. Ch0GateControl10 = 0
3. Set RollOver to 0, set tag Output.Ch0Rollover = 0
4. Enabled Counter, set tag, Output.Ch1Rollover =1
Now when I am trying to read the count from the Encoder by moving the motor (Rotation), the counts are all over the place. I am getting some random number like 9, 22 and so on. Every time I move the motor to max position, the counts are not same, actually some time count is negative number and some time positive, just all over the place. I have already checked the wiring everything looks alright.
Could anyone please advise where I am going wrong.
Thanks.
Hi, I'm new to the forum. My company works exclusively with Allen-Bradley products. I need help with programming roll-over code for this module...
5,655
Hello Friends I'm new to PLC's and am having trouble with A/B's 1794-ID2 encoder module. I have the module addressed, but I need to know how to...
4,835
Good Morning , I am going to be re-working 2 portable machines. I am going to have one main panel with a CompactLogix and 3 PowerFlex...
1,491
I am using an oval gear meter with a pulse rate of 2050p's /L. I am trying to figure out how to program a rate counter to track flow rate at...
2,640
I see no threads about the 1794 ID2 incremental encoder module. I have used Flex logix before but have not done Block transfers to any of the...
3,086
