1794-IT8/A && Leakage Current
Wormfood
Nov 2009
Boise, ID
29
Installing a IR T/C onto a DeviceNet Flex IO drop. Card is a thermocouple card 1794-IT8/A. According to the manufacturer, I'm getting leakage current into the card and it is throwing off my reading.
Testing
1. Hooked regular T/C to point - Reads fine. @ 140 Degrees
2. Hooked IR T/C to point - Reads 312 Degrees
3. Hooked regular T/C into test unit we have - Reads fine 80 degrees
4. Hooked IR T/C into tester - Reads find 80 degrees.
5. Switched channels with a known working T/C - Same result as #1 and #2
Vendor info:
http://www.exergen.com/industrl/irtc/technotes/technote_001.html
http://www.exergen.com/industrl/irtc/technotes/technote_016.html
I can not find anyway to zero out the card based on the companies installation instructions. How do I kill off the leakage current? Will a pull down resistor do the trick?
Just commissioned two new skids for a customer. Each has a 1794 chassis over Ethernet back to an L81. The second module of each chassis is a...
2,414
Hello Im using module 1794-IT8 to read values from termocouple type K. I configured the module to read this type of termocouple and i still get...
2,401
So this is a first time I've had no choice but to use Flex I/O with anything RSLogix 5000. I've got everything up and running, but the values I...
1,980
We are getting ready to do a small project with AB Flex I/O and intend on using a 1794-IT8 module to measure some temperatures. We are using a...
2,372
I have two 1794-IT8/A modules on ethernet. They are not reading the correct temperature. According to the user manual, modules on a Flex I/O...
8,396
