2 Identical PLC on same IP range
pr_wainwright
Jun 2011
Stockton on Tees
109
I have a PLC/RSView project running for a client with no problems. The client has now asked for a second PLC/RSView for a very similar project. The projects are so similar that I intend to use the same PLC/RSView code as the original project with only minor modifications. The thing is that both PLC's & RSView PC's will be on the same IP range. Do I need to change the PLC & RSView project names in the second project or will there be no name conflict problems?
Paul.
keep the first 3 IP bits the same 111.222.012.###
and Mask the same 255.255.255.X
Change the # per device
no problems
iant,
Thanks for the reply. The IP addresses are as you have explained with a different address for each device.
PLC1 10.87.2.231
RSViewPC1 10.87.2.232
PLC2 10.87.2.233
RSViewPC2 10.87.2.234
Regards
Paul.
No problems
Just give your self an IP for the PC/Notebook
Maybe allow say 5 Ips per PLC system
I am building a system that has three identical machines running in a single Logix PLC as separate programs: Cell1, Cell2, Cell3 There are going...
1,644
Hi all, I have a plant that has 7 identical production lines, each controlled by a 1769-L36ERM PLC running 32.11 firmware. These systems are as...
19
5,895
I am thinking about adding a second panelview to a small system. The plan is to use the same MER file in both PanelView Plusses. Will this cause...
2,483
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
115
Hi all, I have a Question about differentiating IP addresses. If i had two identical systems with about 7 IP address devices, would it be smart...
28
5,698
