2 panelviews with slc5/04 on DH+
billyh
Mar 2007
Waco.TX
I have one panelview plus currently connected to a slc504 using DH+.
I've added another panelview plus but can't get it to communicate.
Do I need to set the panelview to a different node or address? It's been a long day and I'm just not seeing it.
Billy
In RSLinx Enterprise (launch the configuration from within RSView Studio) you set the DH+ address in the Target Tab when you configure the 2711P-RN6 driver.
I think this is also accessible from within the terminal itself, but you want to change it in your source Studio project anyhow.
Hello all, I have a question I hope someone can help with. I have boxes (a literal pallet of boxes) with old panelview 550, 600, 1000, etc. I am...
26
918
I have an application where I will be using two PanelView Plus 7s to run two machines that share a common processor. The machines are identical...
404
Can a Panelview Plus 1000 replace a Panelview? If so how? So far the Panelview Plus 1000 doesnt see the file from the Panelview. Thank You.
1,190
Hi! Small question. I have a customer currently that is reporting an issue of 2 different panelviews running the same application connecting to...
2,304
Hello PLCs.net! I am working on revamping my test bench in the lab, I was wondering if someone has had good luck with mounting panelviews without...
3,421
