2012 server Dcom permissions
asterof
May 2007
Califonia
554
Three machines running 2012 R2 SP1 on Dell Blade Servers
Three BoxPC thin clients running Thin Manager software
Three 2012 servers are DOMAIN, Terninal Server, iFix 5.8 SCADA
I am told the only way that the thin clients can access DCOM
on the SCADA machine is by making the thin client login accounts
Domain Administrator Accounts. We have tried for days to use
domain user accounts and it would not work.
Does anyone know if it can be done accessing DCOM on a 2012
SCADA machine using thin clients logging into thinmanager on the Terminal Server running a view node of iFix accessing the SCADA machine
BTW I had GE online and they told me this (see below)
-----Original Message-----
Sent: Tuesday, October 18, 2016 2:28 PM
To: xxxxxxxxxxxxxxxxxxxx
Subject: Update - Case xxxxxx - Issue with a iFix 5.8 Terminal Server Communicating To the Scada
Hello xxxxxxxxxxx,
Glad to hear you got the thin clients working….
With respect to the issue of DCOM, please understand the OPC requirements are dictated by Microsoft. You may be able to use a user domain account, but the permissions were configured for a Domain Admin account.
Lastly, given this is now communicating, please let me know if you have any other questions on this case and please let me know how I should proceed. Thank you.
Regards,
xxxxxxx xxxxxx
Software Support
GE
http://www.ge-ip.com/support
Yes and no. Starting with introduction of UAC all users run as standard users with the ability to elevate . The User has to have Administrative privileges so that it can browse for registered OPC DA servers. Usually it is recommended to create a Group that has all the privileges that are needed to make the DCOM connection and then add Users to that group. They will inherit the permissions of the group for DCOM only.
Also you should set DCOM at the application level if you have an open network. It it is closed, not external access, then you can open it up wide.
I would like to run Intouch 2012 (10.5) stand-alone on Windows server 2016. I know it is not officially supported. Any experience out there?
1,549
Anyone setup iFix 5.8 on server 2012 R2 and connected using ThinManager/client I have an issue they seem unable to resolve
1,900
Hello, I'm actually working with FactoryTalk Historian ME (1Gb), and I need to send the tags to my SQL database on the server PC (Running Server...
2,955
I've Started a VB2012 Project Looking at a OPC Topic in Rslinx Just wanting my tag value to show up in TextBox1.Text Any Idea's why it isn't or...
4,901
Hi All We are planning to Install RSLINX and Factory Talk Transaction Manager on Windows server 2012 R2 Machine. Have any of you guys have done...
3,955
