24v DC drive for samall motor.
gas
Nov 2005
Erie, Pa
531
I inherited a project with lots of problems.
They are using a small motor, 12/24v, 6A and are so far along the motor is a given.
I am looking for a PWM drive 120v AC in and 24DC out.
I haven't found anything out there...any suggestions appreciated.
Space and weight limitations preclude a power supply.
Thanks in advance.
Thanks in advance.
what frequency for the PWM?
Is it 6A at 12V and 3A at 24V?
If so, I think the SUN XMD-01 may be a good thing to try for the motor. It will do 3A at 24V. 6A you might have to do a solid state relay with a frequency output from a plc.
Are you trying to do position or just speed?
drbitboy
Good question...I have no clue.
I searched all the off the shelf drives that spec pwm and there is no spec.
Hi Experts! I'm trying to control a solenoid valve (don't have part number, but I've been told its a 24V DC 30 watt coil) with a PLC output card...
6,612
Hi I am using a Delta sv PLC which gives a 24v pulse sink output which is connected in series with a 2.2Kohm resistor for both step and dir...
5,281
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
554
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,116
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,084
