24V Pulse Extender
Simple off delay timers usually have a 1.0ms input. These would not work in your case.
I would suggest a small Click PLC with Ethernet. This has high-speed functions in the unit.
https://www.automationdirect.com/adc/shopping/catalog/programmable_controllers/click_series_plcs_(stackable_micro_brick)/plc_units/c0-11dd2e-d
Click High-Speed Functions:
https://accautomation.ca/click-plc-high-speed-counting-part-1/
https://accautomation.ca/click-plc-high-speed-counting-part-2/
Hope this helps you out.
Regards,
We've used the Turck "Smart Plug" which is their version of a pulse stretcher.
http://old.turck.us/Products/Sensors/Smart_Plugs/
A nice feature is that it plugs inline with a M12 sensor cordset, giving you an extended output signal to your PLC. As I recall, you set the delay time by manually holding one of the plug leads at 24V. (They make a little gadget for this.) So the delay time is not very precise--the idea is that it's long enough for a slow PLC to recognize the signal.
Hi; I have noticed that at our machines, when pulse frequency of encoder is high, OEM uses 5V encoders instead of 24V. What could be the reason?
2,704
Hi, I am using AB 1766L32BXB PLC to connect convyer kit(which is 24vdc supported)"...
5,878
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
555
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,140
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,104
