3 pos selector switch schematic notation
david90
Apr 2010
ca
202
Does the schematic above say that the selector switch will energize the relay A1 when it's in the neutral position?
Wouldn't it be the same thing if I replace the NO selector switch with a NC selector switch and use the XOO notation? The NC contact would be open when in position 1 and closes when in neutral position.
I read that to say the contact is closed when the switch is in the center position. The condition indicator should be looked at as a conduction indicator, not an actuation indicator. So whether you use a NO or NC contact and a different cam doesn't change the conduction indicator.
Said another way, the important piece of information is where the switch is when the output wire is energized, not what a specific contact is doing to achieve that energized state.
This is personal preference, but if this is a 3-position spring return to center switch I would show the center position as solid and the side position as dotted. I would also show two arcs with arrows pointed toward the center. If it is three position maintained I would show all the positions as solid and no arrows. But again, that is personal preference.
Keith
On the schematic, i think it's fine to draw it as a conduction indicator but I think it will be confusing when building the circuit. For example, to build the circuit in the schematic, I would install a NC contact to the selector switch but which side (pos 1 or 3?) would I install it to? Assume that I'm building the circuit using this selector switch:
How would you deal that ambiguity?
I need some help guys, I need to modified a control Logix 5000 plc ladder. I have 2 BFW pumps running with and auto/manual selector in auto if...
5,720
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
136
Hello all, i am new to the servo drive and this brand also. i installed the automation studio v4.12. i have to configure drive with plc B and R...
373
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
447
