4-20 ma program
Pratik Patel
Sep 2003
new jersy
I want to make program for 4-20 ma with AB-Micrologix1000.
I connect my sensor with one monitor, that monitor have output
4-20ma. I want to use this 4-20 ma output for my plc analog input.
so I read my sensor intensity.
I want to set 4ma is 0% intensity and 20 ma is 100% intensity.
I am doing first time plc program. so please bear me.
pratik
Your message doesn't make the objective of your program or the area of your problem clear. Do you want to know how to convert the 4-20 mA signal to engineering units? Look at the SCL function. Do you want to set an alarm? Look at teh GEQ and LEQ functions. Please provide a little more specific question, and you can get better answers.
my monitor measure sensor intensity in %.
so I want my plc measure same reading in sensor monitor.
and I want to set two alarm one at 60% and onther one for 50%.
pratik
OK - first you use the SCL function to convert the 4-20 mA signal to 0 to 100% engineering units. Store the output of this function in an integer register, such as N10:0. Then you use the GEQ function to compare this register with your limit, and if it is true turn on a bit, such as B11:1/1, to indicate the alarm.
These functions are shown, with examples, in the programming manual. HAve you read them yet?
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
269
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
117
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
136
my ccw softwer stops working when i add and try to open a ladder program.
85
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
172
