485 PORT for VIPA CPU 314
halancas2000
Jul 2010
Bogota
Hi Experts!
I need your help please!
This is my case: I'm setting a VIPA PLC (CPU 314SC). it has two ports and its defatults protocol are MPI and PrOfibus DP.
The profibus DP port is using for expansion rack but my problem : i need to configure the MPI port as PTP port, it means 485 port , especifically,
MODBUS RTU Master but i couldn't configure it!. According to the manual, first it's needed to configure the CPU 318 , then configure
CCP 342-5 as last module and configure it as Profibus DP Master. The next step is my confusion: configure a CPU as Profibus slave and
its address as 100 and according to the manual, after a double click in the CPU, it would appear the "485 option" but it doesnt appear.
Is this procedure OK? I have tried testing different CPUs (314, 318) and changing the addresses but i have not seen the "485 option"
Could u hepl me?
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
361
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
200
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
128
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
771
Hi, I have 1747-L30A Allen Bradley PLC. It has only one DH-485 port. Whenever I have to connect a laptop to the PLC for troubleshooting, I have to...
1,731
