505 Counter/Timer problem
Dan747
May 2007
Louisiana
I'm learning how to program our 505's and have a small problem that I haven't worked out. I have a line that makes widgets. They come down the line at approximately 1 every 3.75 seconds. Input X27 pulses each time a widget goes by. I want to count 10 widgets then turn on output Y27 for 5 seconds, while the counter resets and starts counting the next 10. This seems like it should be a simple thing but I just can't get it to work. Could anyone offer an example RLL of how to do this?
Dan
Could you post your code so that we can take a look at what you have.
Sounds like you have your requirements, just break it down into simple elements.
The time at which they come down the line does not matter. Once your counter is done, you will want to look at the done bit of the counter. You will use the reset command to reset the counter. Use a latch around for the output timer. This should help you. Also, X and Y are not AB ins and outs. I:1/0 and O:2/0 are.
There is a really nice AB simulator for training, but I cant recall its name, maybe someone can help me with that?
matt
505 Counter/Timer
Sorry for not being more specific, yes this is a TI/Siemens 505.
I did figure it out after posting. My biggest problem is that I have been a computer programmer for 25 years, and I'm having to understand that a RLL program does not function in quite the same logical flow as a computer program, but I'm getting it.
Here's a snap shot of my RLL for this, with comments.
If there is a better way to do this I'd be happy for someone to educate me. Sometimes things don't work the way I expect, but RLL programming is starting to sink in.
Dan
Is Y27 ever turning on?
You may need to switch the order of the C21 and Y27 rungs.
It has been a really long time since programming a TI505, but this may be a logic scan thing.
Just a thought. Good Luck.
I've never programmed a TI505, so this is nothing but a WAG.
I assume that the lower connection to the timer and counter functions is the reset line. In the PLCs I know well, when the reset line is true, the timer or counter is reset. Your logic seems to imply that the reset action occurs when the reset line is false.
505 Timer
The timer was what was throwing me in the beginning. On the TI-505 timer the top line is "start/stop" the bottom line is "enable/reset." Both signals have to be present for the timer to run. To reset the timer you turn the "enable/reset" back off. It took me a bit to think that through.
Yes, this works correctly, Y27 turns on for the desired 5 seconds after 10 counts.
I did make one change to remove the rung for C21 to reset the counter and let C20 do it's own reset, not a big change but one rung more concise.
Dan
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
225
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
122
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,284
Hello. I'm using bootp to set an ip address for a 1747L551 processor. The bootp program immediately sees the mac id and I am able to enter an...
1,196
Hello, I inherited a control system one of my predecessors thought it was a good idea to put logic for cant optimization and Kinetix motion...
3,617
