5380 Controler Fault
leighigh
Dec 2012
Colorado
81
I have a 5069-L330ER CompactLogix 5380 Controler.
it ha developed a Fault
(Type 01) Power-up Fault
(Code 60) Non-recoverable Fault.
AB had me update the firm wear from 30.011 to 30.014 no help.
any Ideas.
Thanks for the response but I found that I had to go back 4 saves before the program would reload and run.
I never found the software fault that caused the PLC to Fault out.
Once in a great while I'll be working on a project file and either it has trouble downloading or faulting while programming offline. The fix for me has been to export it as a .L5K file (text) and then re-open the L5K file. That fixes whatever weirdness that it was plagued with.
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
94
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
112
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
546
I had a comms fault between my VFD and Controller (5069-L320ERS2) that started about a month ago and happened maybe once a day to now where it...
290
Hello, Just want to share my "experience" with newly received CompactLogix 5380. It's the first time I'm going to use this one. (I've been using...
1,381
