840D_SL, NCU can not identify the ACTIVE LINE MODULE?
jackie114
Jun 2013
Toronto
Hi, all. We have one 840D-sl system: NCU 720.1 and smart line module (pn: 6sl 3130-6ae15-0ab0)...everything runs well.
We change the smart line module to Active Line Module (6sl 3130-7te23-6aa1), but after config., there is a alarm:
206400: DP003.Slave003.(2): Infeed line supply date identification selected/active.
There is 24V on EP. AND we gave up-edge signal (+24V) to X122.1 on NCU, but alarm 206400 is still there.
There are some parameters:
CU MD: r2 [10]: ready for operation
Supply MD: r2 [45]: switch on inhibit -- remove fault cause, acknowledge fault.
r46: bit0=1: OFF1 enable missing;
bit17=1: OFF2 enable internal missing;
Drive MD: r2 [31]: ready for switching on -- set "ON/OFF1" = "0/1" (p0840)
bit9=1: infeed enable missing;
bit12=1: setpoint enable missing;
bit30=1: speed controller inhibited;
We even use the switch to control the signal to X122.1 on NCU and when we checked there is 24V on it. But the system always gives us the alarm and tells us OFF1 enable missing.
We tried, reset and reboot the system serval times, p3410 is still 5 and p3402 = 1. The LEDs on infeed module are green and yellow, it looks like ok.
Do need you help. Thanks.
Greetings everyone, I have an MMC 103 NCU 573.3 (6fc5357-0bb33-0ae3) to work with my Sinumerik 840D, but the problem is that I can't start it...
1,050
Hi guys, I have this error on my Siemens Control. ERROR 2001 PLC has not started up There's something that I can do? Thanks :bow:
1,455
Good afternoon, I've came into contact for the first time with a Siemens 840D, just curious what software I will need to interrogate it (and...
3,162
Anyone had experience with Siemens 840D controller and systems....:D
2,012
Hi all, I need to send these commands (play, stop, pause, run next block, run previous block) from an HMI (made in Visual Studio with C++) in...
2,214
