A-b 1734 aent point i-o led blinking with red
naag_slet
Apr 2010
bangalore
65
Hello,
This is Naag from bangalore-india.
Here i have attached only one IB-8 module to the 1734 AENT and configured the i-o in RSlogix5000 (IP OF L32E is 192.168.1.100 and IP of 1734 AENT is 192.168.1.101 thumb wheel selection is 101)and downloaded the application.
Problem observation: for every power supply ON to the plc panel upto 10-15 minute everything is working fine and after some time point i-o status LED on 1734 AENT and network status on IB-8 module are getting blink with RED.
So that i-o LED on the L32E is also getting blink.
checked several time by switching OFF/ON the PLC panel found same outcome.
I have connected one stright Ethernet cable from L32E,one stright cable from 1734AENT and one stright cable from my laptop to Ethernet Dlink switch.checked by changing the ethernet cable but same outcome.
For every 10-15 minutes from power ON to PLC it is showing red LED on its Point i-o status.
Please go through with attached screen shot.
Thaks in advance.
Naag.
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,408
Hi, I just bought a 1734-AENT Series C module (Revision 6.01). I am using RS logix5000 and at site we have a running system with control logix...
8,812
Hey guys, got a little situation here which i am not sure if its something viable. We are using a 16 slot chassis with 7 IB8 input cards and 8...
1,807
Currently have an Allen Bradley 1734-AENT (CIP Ethernet) Module, with 2 points of IO. In the first slot is a 1734-IB4 (4 point Input), and in the...
4,906
Hi, I am adding a 1734-AENT with (3) IB8, (1) 1734-FDM, (1) OB8. In my software I only have 1734-AENT/ A available. The card I bought is series...
2,611
