A-B ATA PC Card
franco823
Oct 2007
FLORIDA
I'm trying to use a standard ata card to save panelview applications in it, but when connect card PV "Unformatted card" appears. Tried to format but "Error 324" appears. Is it the off the shelf card the problem? Are the AB ATA cards the only compatible cards panelviews will work with? Please Help.
Which type of PanelView terminal, and what revision ?
PanelView Standard terminals (the 550/600/900/1000) support the older A-B Linear Flash cards through all revisions. Terminals with version 3.0 or later firmware support ATA Flash cards.
I have had very good success with third party ATA Flash cards in PanelView Standard terminals, but I know A-B doesn't guarantee universal compatibility.
Thank you for the information Ken. One more thing, do you know if there is a card size limitation (ie. card can't be larger than 32 MB)where if the card is larger than the limit it wont work? Once again, thank you.
Any size limit is imposed by the FAT16 file system on the card.
I've successfully used cards up to 512 MB, but it's probably been over a year since I used a PanelView Standard.
I do know that any removable media formatted with FAT32 or NTFS file systems cannot be used by a PanelView.
Do I have to create a folder structure within the SD Card in order for data logging to begin? I have a Micro820 that I am setting up as a data...
2,162
I have been having a big problem from moving to a Red Lion G308C100 to a CR3000-0700-00420. Let me say that I'm already working with red lion on...
1,972
So I started a thread at the AD forum... https://community.automationdirect.com/s/question/0D53u00002O4jbSCAR/brx-sd-card-storing-v0v4095 And I...
1,724
Hello everyone. I would like to set up data logging to an SD card so that my data for a couple of trends is stored even when the screen is...
2,353
Cheap PLC that can read Data from its SD card or USB Flash Drive? I'm looking for something in the price range of a Productivity 1000 ($180 for...
4,635
