A B print instruction?
bce123
Feb 2011
texas
1,177
I am tring to setup an industrial printer and have used the AD in the past but need to do it with an AB compactlogix l32e. Does Ab have an instruction like this?
Thanks for the help
The AB 'AWT' commands don't have anywhere near the flexibility of the AD 'PRINT' commands. Prepare to do a bit of combining parts of strings to develop the proper output. It's just how it is.
It took me a few days to troubleshoot the string combination required to get the printer to work right. If you know the model printer, and have any trouble, I could probably help.
The biggest hurdle I had to overcome with this:
http://www.plctalk.net/qanda/showthread.php?t=48387&highlight=Zebra+Printer
The / before the ^ made all the difference (otherwise it wouldn't send the ^ character and AB would treat it like a ctrl key instead.
bce123 did not say that this is a zebra printer. That's just the examples that have been presented. Let's not over complicate things and wait for specifics.
I didn't say it was. Which is why I said if he had any problems he could post his printer model to get more help.
The info about the ^ was just an example of annoying undocumented (at least, in what I had read) string issues that occurred when I was trying to build the proper string commands. I even contacted AB Tech Connect at the time trying to trouble shoot why the ^ character wasn't being written by the Ascii Write command (had it hooked up to a PC with Hyperterminal running). This site ended up having the answer for me after two days of looking elsewhere.
That is one of the more challenging aspects of this, hooking up things that no one else anticipated. If the end unit's manufacturers spent more time on possible connections it would make things easier. Otherwise we can just encourage careful reading and implementation.
Sorry about the lack of info as I am lacking some myself. The printer is a REA-jet I have a few things to learn about it also. it uses stepper motors to pos. the print head as well to do the printing. this will be a retrofit of an existing print system that uses a windows based program to read a string from a compact logix(not working at this time) and i/o to start the printing among other convoluted things. the pc software is very user un-freindly. and I want to do away with it.
Will someone please convert this logic to pdf?
134
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
388
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
151
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
395
I am stuck on a project. I am still somewhat green at PLC programming and had a project given to me to get at BROTHER printer to print via plc...
902
