A free OPC ActiveX control
b370
Mar 2004
Dear All,
If you developing SCADA / HMI within OPC Server and Visual basic. I would like to suggest my COPC ActiveX control. It can connect to OPC within unlimited tags. Especialy, It's free and easy to use. You can download and read simple tutorial at http://scada.cjb.net .
You can use COPC ActiveX control with VB6.0, VB.Net, C#,VC++ and any VBA container.
Best regards,
b370
I had no problem viewing the website, Panic. Yes, it has a popup, but that's because it's on a free host. All those cjb.net sites do that.
Popups suck regarless though... :D
beerchug
-Eric
Ok, you made me try again and I still got same result (blank page with not even a single pixel other than white plus a popup).
But after trying it on another PC it did load properly. I guess
I have to reload IE on first machine :(
Hellow, Anyone knows if there is a free API for the new released OPC UA in firmware 2.0 of the 1500 CPU's ? Thanks in advance, Kind regards, C
1,332
Hi All I have seen multiple questions on this forum about interfacing SQL from OPC Sources (such as PLC), without any good and/or free options...
8,335
Downloaded from the matrikon portal. I wonder, is it a trial or what?:hmmm: Currently im not having access to my plcs so unable to try it...
2,492
I've had to hold my tongue about this for quite awhile now, but it's finally official! The Ignition Platform (evolution of FactorySQL and...
19
18,673
I'm collecting input for a free datalogging version of FactorySQL to include .CSV logging. What I need from you is: would it be useful as...
5,636
