a problem for E3+
angi
Jan 2010
us
361
Hi guys
there is a problem for E3+ when try to connected it with DeviceNet:
I could go online using RSNetworx for DeviceNet, the scanner(1756DNB) looks ok, there is no error message for this E3+ on scanner,but the LED for Communication on E3+ turn into red. my question is how come RSNETWORX for DEviceNet and Scanner could not see the error, and how to fix it?
A solid red Network Status LED indicates either a duplicate node number or the wrong data rate (and that AutoBaud is disabled).
All old E3/E3+ modules without the rotary switches on the front came out of the box at Node 63 with Autobaud enabled. You had to use a software tool to set the Node Number.
The modern E3's are a lot easier to set, but those tiny rotary switches can easily be bumped to the wrong value. I like to use a jewelers screwdriver and rotate them very carefully through the appropriate number of clicks from the top position.
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
471
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
55
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
216
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
155
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
169
