A 'Rare' Siemens S5 Power Output Module???
SPS Steurung
Jan 2008
Earth
Does anyone have experience with the Siemens 6ES5-776-7LA13 Power Output Module? It was generally used on thermo-forming machines to control a large number of small heaters. It was replaced in the late 1990's by the Siemens HS724i system.
I am looking for a user manual or any information possible on it. And yes I have tried the Siemens Website and found very little information. I even tried Siemens tech support but they could not even verify the part number (after waiting 4 weeks I don't think they are going to call back). The only place I have found to purchase these modules from is www.classicautomation.com.
My actual question is whether or not there is a derating factor on the module when all 8 outputs are on continuously at 100% output. The individual outputs are rated for 500w but the OEM of the thermo-former (who is out of business) used 400W heaters. I believe this maybe because of a de-rating factor of the module but with out any information or tech support from Siemens I can not safely verify this.
P.S. Does anybody know of a good Siemens Distributor in the Great Lakes Area?
I believe that usually the last two digits are the release number, generally backward compatible, so a 13 could be used to replace an 11 etc.
Hi all, i was serching unsuccessfully something relationed with this issue. I have a screen with several labels, some of them with the same "Y"...
2,709
Hi! Is there any way to spot error in the code that works right 99% of time? For those who want to dive deeper into my code: I got program...
2,388
I've given up on the FSGateway because it just doesn't want to create a connection (continuous errors in logger about OPCEnum), so I decided to...
1,877
When open offline project on rs5000, if go to online with the controllogix, there is no prompt windows to say if you need to download or upload...
20
6,607
if i wanna do a fb made of some ladder and anothers fb inside. can i pun a fb inside in other one??? if yes. wich db i declare to the ones...
3,142
