A siemens Question ??
rohit_plc
Jun 2013
delhi
81
Iam working on a Siemens 1200 plc using TIA portal v13. its showing error of version difference program built on v11. how can i access program using v13 ?? thanks
You should be able to open it, might you be missing some required packages?
Are you trying to upload it from the PLC or just open a project you have?
To upload you will need v11, which you can download from Siemens, then just open it with v13
OK. You guys helped me out a bunch with my first Siemens question. I found a bunch of issues with integrity checking the PLC programs I was...
355
Does anyone know why my one string is displaying this way? It is causing issues with my HMI displaying it.
283
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,475
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
793
We've got very fast machine whose position controlled by interrupt OB35 set at 2ms. For position reading we use Temposonic connected to TM...
19
2,576
