AB 1734 POINT I/O usage in visual basic
JGax
Nov 2013
Mexicali
28
Hi
I have the idea of create a custom GUI in visual basic, the idea is use hardware that we have in stock and not buy something.....
Is there a way to manipulate a 1734 Ethernet POINT I/O module through a visual basic interface?
Does exist any DLL that I can add to visual references?
and does any of you tried this before?
Regards
Jesus
Hi , welcome to the forum .
You could take a look at Advanced HMI. It's free and is written in VB 2010 SP1 or above . There are drivers for AB Control Logix ( and Compact Logix ) in ethernet and DF1 . There are also drivers for micro logix .
In this forum you can search for Advanced HMI and you will get a potted history of its developement .
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
388
About every 5 minutes we are seeing both network and point bus status lights on our 1734-AENTR blink red simultaneously for about 30 seconds, then...
1,471
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,438
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,427
Hi, I just bought a 1734-AENT Series C module (Revision 6.01). I am using RS logix5000 and at site we have a running system with control logix...
8,862
