AB 1756-IF16 connection with MTL 5041
dasau2000
Apr 2010
Qatar
Hi
We've Allen Bradley 1756-IF16 analog input. Our signals are intrinsic safe signals, so we have intrinsic safe isoltaors MTL 5041 between PLC and instrument at field. Isolators and PLC are in same cabinet and powered by same 24VDC supply. we have about 13 signals and all are intrinsic safe (wiring will be single ended current type).
My question is, can i connect the analog signal from isolator to 1756-IF16. Does it going to be any issue because of the isolator output which is floating? Attached MTL 5041 data sheet also.
Same question for the analog out signal from 1756-OB8 which will be connected to MTL5045 intrinsic isolator.
Dasa
AB 1756-IF16 Wiring
Hi
Dasa
Hi any help???
416
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
161
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
112
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
976
I have an existing 1756-IF16 wired as single ended with all RTNs tied together. Channels 0-3 have 2-wire loop powered devices connected with all...
1,086
