Ab 1769-l30erms safety task properties cip safety errors
ROBOT_ETECH
May 2019
TIFFIN
Hello,
I am working with an ongoing problem pertaining to AB1769 to FANUC R30iA, errors in ETHERNET COMMUNICATION. It is a cell containing 1 robot, a Press, and the automation panel.
The problem is a milisecond related lapse in communication in the CIP SAFETY ETHERNET COMMUNICATIONS between the Safety PLC and Robot. The operator resets and continues. I believe the traffic is overloaded or Need to delay the fault checking. The automation added in the last year.
Question being HOW CAN I CHANGE ETHERNET DEVICE (ROBOT and SAFETY TASK) PROPERTIES in RSLOGIX STUDIO existing running program. There is an identical cell from the same vendor: add-on robot and automation that does not fail. We found the difference in the cells to be in the properties: SAFETY TASK CONFIGURATION settings and in the ROBOT PROPERTIES CONNECTION TAB AND SAFETY TAB there are differences between the faulting cell and non faulting cell. The RPI, CONNECTION REACTION TIME LIMIT are different in the robot properties inside the PLC PROGRAM. In the SAFETY TASK PROPERTIES, there are differences BUT we cannot figure out how to make them the same or better. The settings are "LIGHTENED OUT".
We tried offline, program mode, etc.
Please help and Thanks
STUDIO 5000 V28.00 Standard Edition
Just read other post, Responder stated to that post HE needed GUARD LOGIX.
Is that what your suggesting?
Thanks for replying
I believe standard is no good. You need full or professional for safety related edits.
Maybe someone will verify soon, but I’m pretty sure that’s your issue.
Wauseon Machine tech will get correct software versions tonight and return in morning to make changes.
Thank all for input.
Making sure the devices comm settings in the properties are the same between non faulting cell and faulting cell is a start to eliminating the random ETHERNET comm CIP safety drop between robot and safety plc.
Hey folks, I get an occassional fault on the PLC. Here's the message I get in the Major Faults tab: (Type 03) I/O Fault (Code 23) At least one...
1,350
Hello all, I tried to setup a communication between 1769-L30ERMS and 1756-L72S. As the 1756-L72S was a old project and the version of the...
1,356
We had a Processor Failure yesterday. Opened a new in the box Processor, and could not get BootP to work with it. After a few hours of trying...
219
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
111
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
139
