AB 1784 PCMK B comms cable length
exiled
Jun 2002
England
131
Hi folks, i hope eveybody had a good Xmas and Nuyear.
I want to establish comms with an Slc 5/04 with a 1784PCMK/B card to a 1784-PCM5/B cable.
We need to extend the pcm/5 cable to physically monitor the process around the machine.
What is the maximum length we can go without any errors?
With the 1784-PCM5 you can use the 9pin (DB9, remove the mini) and make a pit tail connection with a 3 conductor cable (Belkin blue hose), then plug into the DH+ and have the cable 100-200ft
This way you do not have to cut your cable....
I can not find the pinout....
But I think its
(top) Blue to pin 1
(bottom)Clear to pin 5
(middle)Sheild to pin 7
This is going from the top DH+ port on the 5/04 to your DB9 on the 1784-PCM5
Search to verify the pinout... or maybe someone else has it??
Thanks for your help gents. What is a "pit tail connection" ive never heard of that expression before?
TIA
But I think its
(top) Blue to pin 1
See PDF and picture below.
TIA
I think he means "Pigtail Connection"
  • PCMK cable pinouts.pdf
  • 1784CP7.pdf
So I book mark a lot of threads and point my customers to them when I get the same question... I took a picture for a customer today so they could see just what I was talking about and I am puting it here so everyone will get a better understanding of the pigtail... this one also has a connector for the 2nd DH+ port on the 5/04 (note: both of the top two ports are the same, DH+)
This is on a 1748-PCM5 cable and just removed the small adapter and use the pinout that Mickey has posted
Hope this helps
Sorry for reviving this thread but I had two followup questions:
1) What is the black connector at the end of the pigtail (outlined in red) called and where can I get one?
2) What is the maximum length I can run for the cable outlined in blue?
3) What gauge wire is required for the 3 wires in the blue outlined cable?
Thank you for the responses Eric and Mickey.
My intention is connecting a laptop with PCMCIA to a SLC 5/04. I'm looking at doing a 300' wire run. Given that this should be sufficient for 100-200ft, I hope I'll be ok.
I am "upgrading" an XP laptop to Windows 7. I have a 1784-PCMK Series A card. Having trouble finding specific drivers and getting the card...
2,854
Hey guys I think my 1784-pcmk card went bad. I was wanting to confirm, and ask what are my options for communicating without using RS232 port on...
1,982
Good afternoon all, does anyone have the driver download or driver files for the old 1784-PCMK/B DH+/DH-485 ? Need to connect to an old SLC 5/03...
3,225
Hello everyone! I have a problem connecting to plc5. I have an old 1784 PCMK card and a new industrial laptop with a PCMK card slot. The laptop...
5,127
Hey guys, I'm new here and somewhat new to controls. My three years of experience so far has strictly been with all new CompactLogix controlled...
2,127
