AB 400C-CR30 safety controller
adisharr
Jan 2010
Rochester, NY
236
Well it looks like this thing is pretty limited. I think they are artificially handicapping the logic so they don't erode their other controller sales.
I have an application where the customer wants to press a button to raise a table and keep it latched until it hits a safety limit switch. There's a light curtain protecting access. So far, I see no way to latch anything. They also only give you two 'logic' levels between safety devices and safety outputs. Even inverting an output takes up a logic level.
I'm sure glad I spent the time downloading CCW at 3.5GB :mad:
If anyone has used this and has a way to latch anything, I'm open to suggestions. The other alternative is to possibly use the Leuze controller I initally wanted to use.
It sounds like you are trying to use the device as a safety PLC and not a safety relay which is what that unit is.
The 440C-CR30 unit is a safety relay and thus does not have standard logic latching instructions.
I actually just need a few basic functions but the way they limit the structure it forces me to do some thing hard-wired. I've used the Leuze and Wieland controllers which are supposedly in the class and they completely blow this this away.
I learned my lesson đź“š
Hi, Sorry for my bad English The 400C show 037:Battery low so we power off the drive then we pull out the battery and found the new one. After 5...
1,248
Hi to all, i am using s7 200 in my machine along with td400c(Hmi)..using ppi cable i can communicate between pc & cpu... Now the problem is i...
1,683
Hi, I want to control a variable from the td. But i want to control from the td a variable set in a range of 0 to 1000. It´s posible to do...
2,584
Currently I'm working in a project, and there is a problem, we need to show what is going on with the CR30 through an app developed in VB.NET, we...
615
Working with this unit for the first time, is there a way to make this unit behave like a safety relay, as in break a PLC output based on inputs...
3,089
