wpuryear
Any insight into this issue would be appreciated.
I'm using an SLC 5/05 processor to send a 485CIF write msg to a NETENI Series D which in turn emails an alarm message. On triggering the 485CIF Write, the EN and ST bit are set (all others clear), the message is transmitted, email received, but after the timeout period, the ER and TO bit are set with the error code 37H "Message timed out in local processor"
Type: Peer-to-Peer
Read/Write: Write
TargetDevice: 485CIF
Local/Remote: Local
Control Block: N15:0
Control Length: 14
Comm Command: 485CIF Write
Data Table: ST16:0
Size Elements: 1
Channel: 0
Msg Timeout: 10
Data Offset: 0
Local Node: 50
Local/Remote: Local
Thanks - Walt
Type: Peer-to-Peer
Read/Write: Write
Local/Remote: Local
Control Length: 14
Data Table: ST16:0
Size Elements: 1
Channel: 0
Msg Timeout: 10
Data Offset: 0
Local Node: 50
Local/Remote: Local
Thanks - Walt
