AB 5/05 Passthru
Jezz
Dec 2002
Kendal
399
Hi All,
I've got a SLC 5/05 OS501 set up to passthru to a DH485 network which works fine ,it talks to 4 SLC 5/03's OS302 and 3 ML1200 with out any problems .Now I've added another brand new 5/03 OS302 Series C now I can see this processor fine when I'm connected to the DH485 network but when I connect to the Ethernet passthru I can no longer see it I can see all the others but not the new SLC 5/03.
I have RSlinx set to auto browse and it keeps flashing up
Browsing - node 12 not found (node 12 being the new SLC)
It also says
Browsing - node ** found (where ** = the other PLC nodes)
Any Ideas as its getting late and I've been preparing this job for the last 2 weeks only to hit this problem right at the end (the law of sod again) o_O
Max node address is set to 31 in the SLC 5/05.
I'm thinking it must be something to do with the fact that the 5/05 is older than the 5/03 ..
Found the problem had to change the Link ID number on the 5/03 to match the SLC 5/05's ,not had to do that before on any of the other 5/03's.
But Hey its working now :p
hello all. i know this topic has been beaten to death but i am still cant get it to work on my end. i have a 1747-L532E and a panelview standard...
2,690
Hello. Before I get chewed out, I did do a search on here for some SL505 passthru help. I noticed there was a small handful of information on...
3,578
I have a SLC 5/05 on the company Ethernet network. This SLC (via 1761-NET-AIC) is connected to the PanelView, part number 2711-K5A2 (via...
1,946
I am attempting to configure devicenet passthru using my 1784-U2DHP cable to a SLC 5/04. I am able to add the Devicenet Driver 1747-SDNTP point...
1,992
Good day! Can SLC 500 5/05 be setup for Ethernet to DF1/DH485 passthru? So that all the devices on the DH485 or a single device on the DF1 are...
3,211
