AB Channel 0 Termination Characters
averellen
Jan 2004
Guelph
112
In Channel 0 Config
If \d = carriage return
would \da = carriage return Line feed
or would I use \d\a?
I've looked all over for info in manuals online. Just can't seem to find anything other then what ASCII hex value I need.
Adam
Thanks Eddie
I will be using Micro, but I think SLC would be the same.
Definately termination characters.
Adam
Good morning! I'm trying to find a DIN rail-mountable 4-0channel PWM amplifier that is capable of accepting a 5VDC PWM with a maximum frequency...
118
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
293
Hi, Had a discussion with a cunsultant about safety and he claimed that for example an Allen Bradley MC1 (two contacts) magnetical non-contact...
1,025
Good day. I encountered a problem when calibrating a channel on the IF16H module. The module is located in the local backplane along with the...
762
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
456
