AB Dataliner Software
I have a PDF copy of the Dataliner DL20 Offline Programming DOS Software User Manual, if that would help.
I guess,
If you just want to edit or add in new messages, just key in those using a standard keyboard [may be hard to one these days]
The manual says
Onboard Editor
The onboard editor lets you create or edit messages, select message
attributes, and set options and variable formats on a Version 2.00 or later
DL40 message display using any of a number of standard keyboards
Check out this link for full manual
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2706-um008_-en-p.pdf
Here is the link I mentioned in post#4. It seems to work offline but I have no idea if it works online or not. I had to extract it with WinRar, otherwise the file thinks it is password protected. I couldn't get the install to work on my WinXP computer so I just clicked on the DL40.exe file. These old DOS programs would rather be on a computer with Win98 or earlier.
Link:
http://www.software.rockwell.com/download/other/zip/dl40%20.zip
Edit:
I have pdf's of the DL40 and the DL40+ manuals but they are too large for me to post. Let me know if you need them and I will upload them to to a fileserver.
Running the DL40.exe file directly should work in XP with a real serial port. I haven't used the DL40 version in years, but still occasionally run the DL5 software with WinXP SP3, so I expect that these old dos utilities are unaffected by the serenumdotsys thing.
It may be sensitive to the path length, so stick to 8.3 naming and put it in a folder right on your C drive. This should also make it easier to save and open files, once you have them done.
Link:
http://www.software.rockwell.com/download/other/zip/dl40 .zip
Edit:
Thanks for the link to the manual !
And thanks for the zipped file !
I too have the unzip password issue.
Where do you find winrar ?
Only sites I see are asking $40+ for it.
Hello Everyone. I have a Dataliner DL50 that I am using for a project here at work. As of now I have two DL40's. One on each line. Those are...
1,522
I have 2 Dataliner DL50 displays (2706-F11J) that are driven from an AB 5/03 PLC. Its old school but works very well for being in service for ~15...
2,755
I have a Dataliner 30 that someone decided to get wet and fried it. As far as I can tell the DL30 gets its info from a TTL output card from PLC5...
1,469
I have read the User and Programming Manual, and Im still not able to figure a few things out. Is it possible to upload messages from a DL20 and...
1,544
(Time to put on your parachute pants and jump into the Way-Back Machine...) I've searched this forum and tried Google-ing for an answer without...
5,901
