AB Devicenet Troubles
rorye
Nov 2006
U.P. of Michigan
I just signed up to ask about some troubles we were having with an AB Devicenet system. I spent about 15 hours on this machine with another guy before we finally found the problem. Two things we found that fixed it - A 3' Devicenet cable that was built wrong and had the shield clamped in the end connectors so it was seeing a ground, (I think this was actually the shortest cable on the whole network!), and the V- was not tied to ground. Once we corrected these problems, everything ran perfect. So, shield grounding and V- grounding only in one spot very important!
simple wiring is key factor in networking but when wiring is faulty or not done correctly, it can be hell of a job to find the problem. to make troubleshooting faster and easier it is good idea to connectorize everything or at least network segments.
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
39
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
128
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
141
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
164
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
150
