AB L36 Ethernet port
Johnny Boy
May 2013
WA
Hi guys,
What is the way to monitor an Ethernet port fault on the L36. I have 3 different networks, Device Net, Modbus and RS 232 controlled from the backplane. I want to turn off output to the 3 networks if I get a fault / communications error on my Ethernet port.
Thank you
Anyone know what these statistics mean or if there is a page that explains it more? I couldn't find anything on Rockwell's website or literature...
72
Hello guys i'm working with an s7 1200 plc with an ET 200S expansion module. The problem is that i can't find the plc when searching in the...
101
269
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
108
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
325
