AB ladder logic
cump61
Jan 2013
Ill
Hi everyone,
Im trying to write a ladder program for the logixPro 500,I want to trigger one output with two inputs,both inputs have to be set within 3 seconds of each other for the output to work.I think can get be with two timers? I know this is a simple program for most of you.But Im kind of new to this and just started back to college at 51,been out of school for 30 plus years.Any help would be great!
From the information you gave I would say to use a branch circuit to use two inputs on one out. And as far as three seconds, a single TON will work fine.
Eli
One example, I'm sure others will have a simpler solution, see attached. I only tested it quickly, it might not work under all combinations. I used 2 timers. I also included the Start PB's on rung 2 even though they are redundant, it was simpler for me to understand.
Thats what I was trying to do,its petty simple no that I see it.I was having trouble with the second rung? Thanks for the help!
Hello, I am going over some old code from days gone by. I would like the expert to confirm my findings to see if I got it correct. 1. B64:22/3...
444
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
170
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
204
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
294
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
230
