AB MicroLogix 1100 Messaging
btaplin
Jun 2012
Ontario
Hello,
I am a computer programmer and need to communicate back and forth with a specific PLC.
I am wondering if an AB MicroLogix 1100 PLC is capable of sending and/or receiving a value over Ethernet to/from a specific IP Address and Port (i.e. to/from a Windows Computer).
Essentially, I need to send 5 bytes of information from the PLC to a computer, lookup a value and send a 0 or a 1 back to the PLC.
Is this possible with the MicroLogix 1100?
If not, is there a simple (very low cost) solution to achieve this task?
Thank you,
btaplin
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
211
I'm having a hard time messaging with a Keyence DL-EP1 using a MicroLogix 1100 PLC. PLC is a 1763-L16BWA B/16.00. I used the Molex Ethernet/IP...
2,806
Anybody have some tips on getting a CompactLogix 533ER to allow messaging with a MicroLogix 1100? Set the CompactLogix up with the 2...
2,359
All, I'm working on a communication project between 2 departments. I have a PV Plus 1250 in one department on a Micrologix 1100 (RSLogix 500)...
2,308
I have two Micrologix 1100 units, and I would like an energized output on one unti to trigger the same output on a remote unit connected through...
4,487
