AB Motion coordinated Question
Miguel.itlac
Apr 2020
Mexico
Hello Everyone 🍻
Im working with Coordinated Motion instructions, specifically MCLM instruction and I Would like to know if there is a way to know the exact End position (XYZ) when parameter Command Tolerance is Set since i need to calculate the distance to the end point, there is no problem as long no command tolerance is set cause I can find the distance using AB=Sqrt ((x2−x1)**2+(y2−y1)**2+(z2−z1)**2) but since some points have command tolerance the new X2,Y2,Z2 are unknown. Hope I was Clear 🤞🏻
Thank you in Advance.
I have a unique project and will be commissioning it next week. It involves two servos that are both connected to the same belt in an H-type...
22
14,205
I have two 2198-P070 bus power supplies for that I’m using for four Kinetix drives, 2 drives per power supply, all controlled by one processor...
1,439
Hi, I have a project to automate a molding machine. It meters out a 2-part resin into open face molding plates, closes the plates, vacuums them...
3,256
Does anyone have a simple example using the MCLM instruction in Control Logix? This job basically requires moving a piece of equipment from point...
5,881
I've been fighting with a Micromotion 1700. Can't get into the configuration area. It's as if the optical sensors are disabled or locked out...
65
