AB Panel View Plus 7
andave
Aug 2017
Toronto
What do I need to install on my computer to get recognized new AB PV +7. I have a yellow question mark in RSlinx Classic lite, EDS files had been installed successfully.
Thx
According to Rockwell KnowledgeBase the firmware of the PV7+ needs updated to ver 8.0 or higher.
Also, it can NOT be upgraded over Ethernet, have to use USB or SD card.
BF23124 | Access Levels: TechConnect
Could someone tell me whats is firmware version on my PV7+ according to the attached picture, please?
I have Panel View 7 + v.10 and FactoryTalk V.8. I checked compatibility on the site (see attached file). What can I do in my case? Can I downgrade Firmware on PV7+ to one of the compatible version? or any ideas
What exactly are you trying to do? Yes, if you have FTview me version 8 that you are using to develop an application, you will probably have to downgrade the firmware that is on the terminal.
I have a programme which was developed on FT view v.8, the old one PV is obsolete. That’s why we bought new, only PV 7+ available for sell now. Actually FT v. 8 doesn’t want to recognize mer file from FT v5 ask to use “Legacy Tag Database Conversion” if some one familiar with it please let me know
In general, a PV+ 7 with v10 firmware can run a Runtime (*.MER) application that was created for any older firmware version. ActiveX controls and KepServer drivers would be my principal concerns.
Have you tried moving the MER onto the terminal with an SD card or USB drive and just running it ?
Updating the FactoryTalk Linx (or maybe the whole FTView Studio installation ) to use the Upload/Download network utility, or de-compiling a *.MER from an old system, are separate considerations than "can my new terminal run this old project".
Thank you for your suggestions!
I have tried to move MER to the terminal it's working but with the wrong resolution, I can't see any data from PLC on it. I definitely need to do it in Factory Talk Studio. As you recommend I can't to upgrade FT v.8 to higher version because of money matters on my work))) Could you tell me about de-compiling a .MER you mentioned.
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
295
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
166
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
343
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
900
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
898
